How do I fix my laptop if the screen is pink
My laptop screen is pink and I can't fix it
HI,
Update the Graphic driver and check whether colors back to normal, if not
Connect the laptop to external monitor and check any abnormal color appearing the external screen if yes you have a bad graphic chip. if you can see normal color in external monitor fault comes from Display or display interconnect wires, you may have to change it
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 3,181
