How to fix recharge plug in?
Cannot recharge tablet because cord doesn't stay in on tablet. How can I fix this as the area seems loose.
It depends on the extent of the damage to the charge port. You may be able to squeeze the metal surrounding it back together with a pair of pliers if the port is otherwise undamaged. This would require you to remove the back casing.If the port is damaged it may need to be replaced.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 188
