メインコンテンツにスキップ
The Beats Pill is a small, portable Bluetooth speaker from the Beats by Dre line of products produced by Beats Electronics LLC. It features direct audio and Bluetooth connectivity as well as an internal microphone to conduct phone calls. This device is fairly capable of being repaired due to its intuitive construction.
My beats pill dont work
my beats pill 1.0 was working yesterday, i plugged the charger on it , when i removed the charger it doesnt turn on and the charger usb is lighting red even the charge is not plugged on it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
コメントを追加
3件の回答
最も参考になった回答
You can try charging it form a computer. If that helped, your charger is faulty.
Also, here's the way to reset it, in case charging still doesn't work.
Press and hold the b button and the power button for 10 seconds
The LEDs will blink red and white 3 times... You're done.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
This works like magic!!!
さんによる
コメントを追加
When I use a different charger, my pill don't charge or go on. It happened before and lasted a week or two and then it started to work. What's the problem?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I think my charging ports all screwed up because I have to hold the charger a certain way and it doesn't even stay charging long. I don't have original charger either
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mouataz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 19,680
