メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
締切られた回答
Keeps rebooting after screen and powerbutton flexcable replacement
Before i started this repair there was a defect at the screen.
All blue and white stripes..
I backuped the phone with itunes (touchscreen worked perfectly fine)
So the phone was working only the lcd was broken..
After replacement of both parts am i now stuck at apple logo rebooting...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Where did you buy the replacement power flex? Did the part # stamped on your part match the original? Does the top sleep/wake button depress (click) at all? If no, you likely installed a lousy aftermarket part where the power switch (under the button) is too tall, and therefore will remain pressed down after you tighten the two screws that attaches the switch to the small plastic bracket on the top of the phone. If yes, you still may have a bad power flex, as I have ordered this particular part from about 7 ebay sellers to date, and have found NONE that actually fit/function on the Verizon 4/4S's reliably.
Some guys will try to "make it fit" by backing the 2 screws out until the bracket flops around and/or the screws come out and toss around inside the phone, risking a short! I have yet to find a reliable source for this part that is not an "Official Apple OEM" part! Please let me know if you do!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 6
今までの合計 66
