Will LCD from a Mercury work in an Onyx?
Will the LCD assembly from a 400 MHz Titanium Mercury work in a 550 MHz Titanium Onyx?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I finally got a used Mercury laptop for cheap. It had a bad logic board. I can confirm that the logic boards and keyboards on the Onyx and Mercury are not interchangeable. The Onyx uses PC 133 RAM so it can be used in a Mercury (PC100) but not vice versa. However, I was able to successfully transplant the Mercury's LCD assembly into the Onyx and now I have video. The optical drives, modems and hard disks are also interchangeable.
このアンサーは役に立ちましたか?
Since they have different part numbers I would think they are not acceptable swaps, but wait for Ben to be sure. Mercury 661-2539 Onyx 661-2568 Ralph
このアンサーは役に立ちましたか?
If you have the other display compare the connectors and cable lenghts. Ralph
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 617
