メインコンテンツにスキップ
A Makita angle grinder released in June of 2010. Model number GA4030K.
Angle grinder won't turn on after I dropped it.
I was using my angle grinder to work on a small project the other evening when I was startled and dropped the grinder off of my work bench. Now, when I try to use it, the grinder won’t turn on at all. I tried plugging it into several different outlets throughout my house and that doesn't seem to be the problem so I think it must be the grinder itself. Is there any way to fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Your angle grinder may be making noise because it is overworked. Machines, like humans, don’t function well after heavy loads for prolonged periods of time. It is recommended that you allow the device to spin freely after a moderate amount of difficult work before resuming your project.
The angle grinder is fixable - visit the ‘overworking’ link on the troubleshooting page found here:
Makita GA4030K Troubleshooting
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The answer provided does not match the question.
さんによる
コメントを追加
回答を追加する
Nyssa Backes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 6,538
