The Canon Vixia HF20 is a compact, ultra lightweight high-definition camcorder.
Ke'Andra @keandra
評価: 1
投稿日: 2015年4月28日
If you do not have the proper tools to fix the LCD Screen button, as you suggested, what could be an alternate solution?
この質問は役に立ちましたか?
Taylor Morris @taylormorris
評価: 225
7
You can use household items like tweezers and a knife with a fine tip to try and unscrew the screws. Another household item that could be used is needle nose pliers and a screwdriver to pry open the screen.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
