メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
締切られた回答
Charge port, home button, and headphone jack not working
I replaced the plastic back casing of the iphone 5c with a new one. I have plenty experience working with these phones and something has happened that i haven't run into before. Everything went back together fine in the new case. Turned it on and the home button will not work along with the charging port not recognizing the charging cable. All the while the phone is stuck in headphones mode. I am not sure if the mic works or not but i'm thinking it might be the cable that works all of these functions. Have you guys ever ran into a problem like this? If so what do you suggest I do? Thank you in advance.
Devin
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Just replace the whole charging port/mic/home button/speaker assembly. As you may have noticed, these are all lumped into 1 component, so replacing it would most likely fix all your problems. hth.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 634
