What can I do with a damaged eMac?
I took my US bought eMac and plugged it into a UK socket, and it blew. Is it worth fixing? Any idea how much that should cost? Thanks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
kitbaker1, "Is it worth fixing?" Depends on what failed. Check the power supply. It is possible that the damage is minor, i.e. Fuse or capacitors. Could be an easy fix.
このアンサーは役に立ちましたか?
How can I change the fuse?
rrame which fuse?
You could always turn it into an aquarium ;-}
このアンサーは役に立ちましたか?
There is a lot of protection built in to help with your problem. What model emac is it? I agree, it could just be the power supply.
このアンサーは役に立ちましたか?
You can take in it and have the power supply board checked out or replaced. May not be worth the time and cost to repair it.
Ron
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 25
今までの合計 683
