cannot get on broadband other devices ok
Nexus 7 2013 tablet 7" cannot get on line says incognito how do I free it.
Go to Settings > Wi-Fi > Select your network from the list > Tap it then hit Forget.
Check That your mobile operator is listed
Ensure that you're at a location with Mobile Broadband/ Home Wireless Broadband coverage. You can check coverage at your address .You must be in a 4G Plus or 3G dual band coverage area to access the Mobile Broadband network.
Ensure that your Mobile Broadband/ Home Wireless Broadband SIM card is activated
On some devices having Wi-Fi and/ or Bluetooth activated can override a successful 'Cellular' connection to the internet.
If you're able to, switch Wi-Fi and Bluetooth off on your computer/ tablet and try to access the internet via your Mobile Broadband /Home Wireless Broadband service.
If you’ve tried all of the above and you still can’t connect to Wi-Fi, then further investigation is needed.
このアンサーは役に立ちましたか?
It was helpful but I am still having prblems. Further investigation required
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 80
