its stuck talking a foreign language
My apple ipad2 it stuck in a foreign language I've tried several things please help
Tapping the "home" button three times in a quick sequence should turn it off. :)
このアンサーは役に立ちましたか?
Hello but that is for quick access for the options you asked to turn on like assistive touch, voice over or invert colors but not language
Hello you may have changed or someone changed your text language so this is what you will do: (P.S. I am using ios 8 so you might probably experience some difficulties if you are not using ios 8) First go to settings which looks like a gear, then press general which also looks like a gear and then in the 8th group last icon is saying language and then press it and the first icon will say ipad language, press that then change the language to english
このアンサーは役に立ちましたか?
Oh and yeah this might help you, language and region is just near the reset button
このアンサーは役に立ちましたか?
can u tell me how to change the launge
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 986
What have you tried so far?
Tim さんによる
i need to change the launge on tablet
Lucille Johnson さんによる
