メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
250GB HDDとWi-Fiを内蔵したXbox 360のスリム版も出る。修理には複雑なこじ開け作業と特殊な工具が必要です。
XBox 360 S does not (start/complete) boot sequence.
Got the console from someone who claimed the unit would work and then freeze up after a few minutes.
He needed the original power supply for his replacement console, so I bought one to use for myself. One plug tested at 5V. The other tested at 12V. I don't remember measuring current. The console AC adapter was plugged into a surge protector sharing a TV, an HDTV antenna receiver, and a laptop AC adapter.
I used an HDMI cable which was working on an original XBox 360 console and then an OEM component cable.
I can open and close the disc tray with an audible beep.
Hitting the power button gets me a green light and I'm forgetting whether there was a beep.
Using an original XBox 360 wireless controller, when I pressed the XBox Guide button to power it up, all four quadrants on that button started blinking. I replicated the same results using an original XBox 360 wired controller over several USB ports, but not all of them.
I believe the fan was spinning in all instances.
The TV still has yet to receive a signal (whether on HDMI or component).
I also noticed ... an X-clamp! ... in the teardown guide. After fixing several original XBox 360 consoles, I really want to get rid of the 360S' X-clamp and replace it (and perhaps the thermal grease).
What else should I try and examine in order to repair this console?
Thanks for reading!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
9件の回答
I think it's totaled
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
did you try replacing the RAM drive or the motherboard?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I agree replacing the motherboard will "fix" the problem. I am still interesting in working with the original motherboard. As for drives and RAM, I am only familiar with the HDD and the motherboard's internal RAM.
さんによる
コメントを追加
that may fix the freezing
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
and for the connectivity try replacing the HDMI output that is on the back of the X-box 360 S
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I hope this will be helpful
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
sorry that all of my answers were all separate
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
im actually not entirely shore if it uses RAM sticks/drives or if it's built into the motherboard of the xbox
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
this type of problem is also more commonly know to happen to PCs as well. and generally how you fix it is by re-installing the OS of the PC, so if you can figure out a way to get a copy the OS of the xbox and then re-install the OS you may be abal to fix the problem. I had a similar problem with my laptop and a friend of mine fixed it by re-installing the OS, so I think it my be possible to do it with your xbox
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Make shore not both the componant and hdmi are plugged in
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lkvee さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 4,041
