メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
Damaged IR cable
Had the same problem ... except the leads just pulled out of the "connector" to the logic board
This also happened with the connector to the "fan" ... was able to get a new fan with the connector which I was then able to re-connect the fan to the logic board
The SSD which I installed went out couple days back ..
Removed and have been using for two days, in an external USB 3.0 with no problems
Putting together just now .. dropped one of the small screws used to connect the "wifi cover"
When pulling the logic board back ... the leads "pulled" out of the connector on the logic board
The "connector" to the logic board in both the cases of the "fan" and the "sensor connector" had become "brittle" and stuck together .. would not separate and caused a failure in both cases
Now I looking for a new "sensor cable" in able to correct this problem
Any help would be appreciated
Will be removing the remaining parts of the mac mini .. the logic board is out
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Here's the IFIXIT guide: Mac Mini Late 2012 IR Sensor Replacement. The Apple P/N: 992-9558 or 923-0251 IR board w/cable.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
This was INCREDIBLY helpful! I tore my cable while installing a second SSD, and thought I might have to take my computer in to the Apple Store. Thanks to you I have ordered the part and am waiting to install it. Meanwhile, everything seems to be working just fine, except that I don't have a power light. Could you possibly tell us what this cable does? Do we even need it? Or perhaps I should say, why do we need it?
さんによる
While trying to add a 2nd drive to my 2012 mini I pulled the socket for the IR Sensor cable off of the motherboard. I didn't repair it because I don't care about the ability to use IR with this machine, but I did notice that a side effect was the power light no longer seems to work. So I'm guessing that the IR Sensor assembly also controls the power light.
さんによる
@paul - They share the same cable connection and are both mounted on the same board.
さんによる
コメントを追加
You could reconnect it back with tweezers and you have to remember the orientation of the wires and not crossed them. The wires lined up straight into the connector.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
wessongroup さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 28
今までの合計 4,702
