メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
I need more than 8GB
When I purchased this FIRST Retina MacBook Pro, I waited over 6 weeks. I ordered the 8 GB RAM model, which is the first MacBook to have soldered in RAM.
No one even mentioned that to me as everyone was so excited about the Retina screen. Now Apple makes the 15" model with 16GB RAM as a standard.
No 8GB models are made anymore.
I need more than 8GB since updating to the latest version of Yosemite 10.10.3.
I feel Apple should have let me know about the RAM not being upgradable.
I've been using Apple products since1986. That's 29 years of many, many products.
They should do something for me, as I've been a loyal customer and am on disability, so
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I can't even afford a newer model.
Any suggestions
さんによる
コメントを追加
1 件の回答
ベストアンサー
@Brian - Nothing you can do to increase the RAM it is what it is. But you are likely hitting a different problem here which makes you think you need more RAM when you really don't!
You see, your SSD is also used for Virtual RAM! So when your SSD has too little room left it will slllooowww dooowwwnnn your system!
OK, how to fix...
The first thing here is to do a good housecleaning getting rid of any old junk you just don't need. Here is a good housecleaning app to flush-out old log & cache files Disk Doctor
You may want to consider deleting your iTunes Movie and TV shows (or your music if you have a lot). You'll need to have iMatch services enabled so you can stream them from Apple when you want them over the network.
The goal is to leave 1/4 to 1/3 of the SSD free, If you really can't get to this its time to get a bigger SSD. Here's one source: Transcend JetDrive 725.
Lastly, I would also recommend you get an external drive to hold anything big and/or important (copy). If you can't swing the upgrading of your SSD right now. Besides if you set it up as a bootable drive you can use it to help maintain your internal drive with Disk Utility.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Brian A Marder さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 128
