メインコンテンツにスキップ
Repair and disassembly guides for Acer Iconia Tab tablets.
355回答 すべてを表示
How to fix shutdown of an acer iconia B1-730?
My acer iconia 7 B1-730 would not charge and turn on at all after randomly shutting down when its battery was at around 50%. Don't know why either the charger or the device itself, but still it won't turn on, is there anyway of fixing this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
最も参考になった回答
You can go through the easy steps first, try a different cord, try a different brick. Most likely though your issue lies with the battery or the board. You can order a battery online if you are confident enough to change it out yourself, but if it's a board issue you'd be better off getting a new tablet rather than spending the money to fix that one.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Christian Balon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,817
