Why won't my phone connect to Wi-Fi?
When I try to connect to Wi-Fi my phone will not connect. When I am in range of network routers my phone does register the available networks but when I try to join one it does not connect.
There are a few things that could be causing this issue:
1.Issue with the device's Wi-Fi settings:
SOLUTION: Select the Wi-Fi that you are trying to connect to and tap "Forget." Then reconnect by selecting that network again and entering whatever password may be needed.
2. Router Problems:
SOLUTION: Unplug its power, wait 10 seconds, then plug it back in. Wait 20-30 seconds for the connection to reestablish.
3. Incorrect Date and Time:
SOLUTION:If there is a discrepancy between your phone's date and time and the router's date and time, the connection may not work. Make sure they match.
For more information regarding this issue see: HTC Desire V Troubleshooting
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 507
