メインコンテンツにスキップ
HTC Desire V smartphone with 4-inch 480x800 display, 5-megapixel rear camera, and Beats Audio.
2回答 すべてを表示
締切られた回答
Why won't my device charge?
When I plug my HTC Desire V in to the charger it will not charge. The battery indicator on the device shows that the batter is not connected (the lightning bolt indicating it should be charging is not present) and my phone doesn't charge no matter how long I leave it connected to the charger.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There may be a couple things causing these issues:
1.Broken Charger:
SOLUTION: The charger itself may be broken or defective; if this is the case you should purchase a new charger.
2. Broken Charging Port:
SOLUTION: The port to connect the charger on the phone itself may be broken and need repair. You should contact the manufacturer if this needs repair.
For more information: HTC Desire V Troubleshooting
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 171
