la mégane II 2005 ne repond pas electriquement
I assume you are talking about the pas = electronic power steering , it has to go onto a Renault diagnostic unit ,Renault will charge you appx €1500/2000 for another unit ,but there are companies out there that are a lot cheaper !
このアンサーは役に立ちましたか?
Ma megane coupe le moteur aprer chaque demarage et elle ecri sur hordinateur panne de l'injiction
このアンサーは役に立ちましたか?
google ECU TESTING or go onto youtube and check out faults with your model !
Solder used in the EEC has a high alloy content [ they dont like lead ] so the joints suffer from poor conductivity its a common problem !
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 3,670
