メインコンテンツにスキップ
Dell Studio 1537, model number: PP33L. Released August 2008, with Windows Vista by default. Repair for this laptop is straightforward and requires only common tools.
5回答 すべてを表示
Why does my battery only last 30 minutes?
I've had this laptop for a few years now and it seems every time I use it off the charger the battery lasts less and less. What should I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
選択されたソリューション
After several years many batteries slowly lose their ability to hold a charge. Most likely it is easy to fix this simply by buying a new battery and replacing the old one.
In the mean time, turning down the screen brightness and keeping the number of running programs to a minimum should help make the most of your batteries potential.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I have the same problem. But the battery is less than a year old and was replaced by Dell for the same reason.
The battery life started going down after a few months. There is no reason anyone should sell a battery that unreliable.
さんによる
コメントを追加
回答を追加する
Zach Dylag さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 41
今までの合計 5,640
