I plug in my tablet, why won't it charge?
I plug the tablet into the charger, but it will not charge. Why?
You might have a damaged charging port. If your charging port is intact and has little to no damage you will have to replace your battery. Here is a link to replacing the battery Ematic FunTab 2 Battery Replacement
このアンサーは役に立ちましたか?
mine will do the same but it will show the battery charging for but then will go blank and won't turn on from the power key or nothing... keep it on the charger?? what do i do???
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 1,101
