メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
New battery dying quickly.
I just replaced my battery in my computer and it's dying very quickly. I've been on it for probably 20 minutes and it's already at 89%. Is this common in new batteries or did I get a dud? My keyboard lights are off and my screen light is less than 50% so I know that can't be a contributing factor.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
How does this compare with the previous battery's average performance?
さんによる
Well, that battery completely crapped out, so much, much better. I would say before it burned out it would take about 2 days of average use before I had to recharge it.
さんによる
Hmm, then this battery sounds like a dud to me, I'd give it another 2 cycles and then go from there.
さんによる
2.3 GHz Core i5 (I5-2415M)
Intro Date: February 24, 2011 Disc Date: October 24, 2011
Order No: MC700LL/A Model No: A1278 (EMC 2419*)
Subfamily: Early 2011 13" Model ID: MacBookPro8,1
Std RAM: 4 GB Std VRAM: 384 MB
Std Storage: 320 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
さんによる
The last four figures of my serial number are: DH2G
さんによる
コメントを追加
3件の回答
ベストアンサー
This really depends on what you are doing in that 20 minutes. It also depends on if you got a knock off battery, what the maximum charge is. Download Coconut Battery to get a much better look at what it's doing an let us know your results. It also depends on which Mac you have, so please give us the last four figures of your serial number.
http://www.coconut-flavour.com/coconutba...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Probably trash battery, all batteries available for this are knockoff $@$* or used with cycle count reset. People refurbishing old cases with new cells are hard to find, you will have to find that or settle with trash battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello,
I have the same problem. I bought a new battery for my MacBook Pro Unibody mid 2010 (under OS X El Capitan) on iFixit website. After few weeks of utilisation, my battery can't be used during more of 1 hour... An idea ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
morgenlray さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 798
