Why will my device not hold a charge without being plugged in?
My device works while it is plugged in but as soon as I unplug it, it dies.
You should consider replacing the battery. If the device can power on when connected to a charger but will not power on when not connected to the charger is a sign that the battery can not hold a proper charge to power the device. Replace your battery with a new one and that should fix your problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 321
