メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
Camera flash not working
My Iphone 5s Camera flash doesnt work, its supposed to have two leds, the yellow and the white, the white doesnt work so i press the flashlight icon in control center and it gets highlighted as working but nothing happens, when i switch to video mode it doesnt light up, i notice the LED or bulb doesnt work because when I take a picture with flash ON the yellow light flashes but theres no flash on pictures, so Its not a software problem, please tell me how to fix this problem and the replacement i need to buy, thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
3 件のコメント
my device camera as well as flash not working . I there any way to fix it
さんによる
it supposed to be yellow and white flash but my iphone 5s flash is just white which still works
さんによる
My flash went out as well how can I solve this problem
さんによる
コメントを追加
6件の回答
ベストアンサー
You need to buy a power volume flex as the led light is located on that
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
This was the solution to my problem thank you very much!
さんによる
コメントを追加
I am also facing this Problem. My volume down button is also not working.. First the volume button fails then Flash of the camera. Amber led working but white one is not!!
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Its the power volume flex, that is involved in volume has the led from flash lock button etc, this piece is cheap and replaced in 15 min!! Good luck!!
さんによる
was it safe? I mean repairing? cause I am afraid that something other will not mess up
さんによる
Well, this piece involves a lot of the phones features but just follow the video and i guess you'll be fine, but if youre not the the "i'll repair it myself person look for someone to fix it for you, obviously experienced.
さんによる
can u post a video?
さんによる
Sania nadeem,
Finally I fixed this problem to replace the (power volume and flash light) single flex...
さんによる
コメントを追加
Here you can get a power volume flex http://www.iboxfix.com/flex-ribbon-c-164...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
same to sania
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my iphone 6 flashlight is working on Video and flashlight but When I taking a picture with flash, white led is working but Amber led is not working.. because of that picture with flash is being dark !
Do you have any idea What is the solution ?
thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i;gt9 6tp/y8 g;p.gilbuj,gbulihilihh
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 20
今までの合計 24,676
