メインコンテンツにスキップ
Wi-Fi付きの初代Apple iPadは16,32,64GBから選べます。モデル番号はA1219。修理は複雑な作業はなく、ヒートガンなどは不要です。
130回答 すべてを表示
What is the thickness of air space under the iPad glass?
From the teardown, we know that the iPad glass is aproximatly 1.18 mm thick.
We would like to know the thickness of the air space between the iPad glass and TFT, or if there is no air space.
If there is another kind of material (or materials) between the TFT and glass, we would like to know what it is and how thick.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
We have one apart right now, and the gap looks to be anywhere from .4 mm to 1 mm. The steel frame around the outside of the LCD is about .4 mm thick, and there is also a thin foam gasket attached to the steel LCD frame that would increase the gap between the LCD and front glass by a small amount.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
As far as material underneath the glass, if you're asking about a fluid or sheet, there isn't anything. The air gap could probably be measured by another one of our guide makers; maybe they'll chime in later.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
thomaselmaraghi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 7
今までの合計 3,630
