メインコンテンツにスキップ
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180回答 すべてを表示
締切られた回答
How to fix my screen from randomly tapping?
I replaced my own lg g3 screen after it cracked and damaged the digitizer. I bought a screen and digitzer replacement combo and proceeded to replace it according to the guide. After a month of use, the screen began to randomly tap and behave erratically. I then narrowed it down to the following, when I press the lower part of the bezel, the part that says LG, the screen begins to randomly tap around the middle of the screen and doesnt stop until i lock it. When I unlock it, I can use the phone normally but as soon as I touch that lower part of the bezel everything goes nuts.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Where did you buy these parts from, where they cheap or on sale. They may be damaged themselves. I advise looking on amazon for parts with good reviews. Also I would replace the digitzer first, to see if that was the problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'm having the same issue and this is my 2nd LCD/digitizer I bought off of Amazon. The issue is the connection from the LCD and motherboard; which is located right underneath the LG logo.
In addition, after reading some other forums on this issue, there's some software issues when you install a non-LG LCD onto the phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,462
