メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
I am still receiving "No Service"
Hello, I did an entire iPhone 5 teardown and rebuild. I have tried everything posted above, and I am still receiving "No Service" The iPhone recognizes when I remove the SIM card. I have tried different sim cards as well and resetting network settings. I do not know what is causing it to say No Service, but it is very annoying. EVERYTHING on this phone works besides cellular.
Since the charging port flex contains the cellular antenna I have recently looked around that area a lot. I will probably end up buying a new charging port assembly, but I want to make sure that is what is actually wrong. I have noticed the flex cable that wraps around the screw all the way in the bottom right hand corner of the phone it torn but still making contact (I am assuming that is what connects the signal to the frame?) and there is a flex cable that wraps over the top of the headphone jack that also got torn, but the headphone jack still works fine. So I am not sure what that cable connects too, and I do not see it in the part on eBay either. (http://www.ebay.com/itm/Black-Iphone-5-5...)
PLEASE help i have looked EVERYWHERE and cannot find anything to help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Ryan, post some images of the damaged ribbon cables with your question. That will allow us to see what you see. Use this guide iFixitでの質問に画像を追加する方法 to help you with that
さんによる
コメントを追加
3件の回答
最も参考になった回答
is this a phone that you just bought? Call the carrier with the IMEI to see if it has been blacklisted. Sometimes a good ESN can turn bad after a few days/weeks after someone turns it in for an insurance claim. That would make the phone show no service.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try going to >settings >time & date >click automatically set time and date off then back on again. Then restart the phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Connect to Wifi and turn flight mode on and off.
After this reboot your Phone and your phone will recognize your sim card
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ryan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 197
