メインコンテンツにスキップ
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
63回答 すべてを表示
went to sleep mode, and is not switching ON
Recently, my Dell Laptop Inspiron 1545, went to sleep mode, and is not switching ON again. It is as though it died. I everything from pressing the power button for a minute continuously to removing the battery, plugging it back and then pressing the Power button
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
選択されたソリューション
The problem was due to accumulation of dust in fan area and the fan would stop, increasing the heat in system and the system was shutdown due to high heat.Just opened and cleaned it now Ola everything is fine.Thanks everybody for answering.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Last time I had someone with this problem, the charger was dead, and the battery ran dry, and that's why it wouldn't turn on.
Are you sure the charger is working?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Also, the trick you described above would go:
1 remove battery and charger (all power sources)
2 press power button for 10-20 seconds
3 supply power again (battery and/or charger)
3 try to turn on normally
さんによる
コメントを追加
回答を追加する
Harsha Warrior さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 327
