Why is my battery not holding a charge?
After a full charge, the device will only stay on for an hour or two.
Be sure you are using the charger that was provided from the manufacturer. Generic chargers tend not to charge the device properly and may kill the battery cells.
If you are using the appropriate charger, and your nextbook is still not holding a charge, it is likely that your battery is dead and you will need to buy a replacement.
このアンサーは役に立ちましたか?
So what battery do we buy & where are the guides on how to do this ?
I have the same problem, I need a new battery.
please give me something to do
Charger will not charge battery give help on what to do
Well we have to use a 5 volt battery charger what we do then
How old is the battery?
Over time, rechargeable batteries lose their ability to hold a charge.
It might just be time to replace the battery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 2,799
1件のコメント
my nextbook wont comeon at all
graceharris301 さんによる
