gateway power on but screen stay black
power light come on but the screen stay black
“Blank/Black Screen” on a Gateway Laptop
Ridiculous problem.
Simple fix.
This works 90% of the time.
Turn on Laptop. The tiny blue light means it’s on.
Top left corner of the keyboard.
The button next to “Esc”.
Labeled “LCD” - Better known as “F1”.
Press it.
All good?
I hope it was that simple.
I also hope someone at Gateway does the company a favor and removes that button.
このアンサーは役に立ちましたか?
That worked for me. Thank you so much I can't believe it was that simple. Very appreciative ❤️
I don't know whether to to kiss you or punch my laptop first. You're amazing! Thanks!
It didn't work for me!!!, 🤨😭😒😠🤬
Unfortunately, my F1 is a "Zzz" button. Still tried it, but nope.
I was on my computer and than the screen went blank but shows it’s on so I’ve tried everything in the last 3 hours and it still hasn’t worked
Take the memory out. Mine did the same thing.
このアンサーは役に立ちましたか?
Are you saying to replace it ? Or just take it out and try to start it?
The idea is to reseat the memory module(s) i.e. remove/replace, in case it is a faulty connection between the memory module and the motherboard preventing the laptop from passing POST.
Be sure to disconnect or remove the laptop's battery before removing/replacing the module(s) to avoid damaging them electrically.
3 possiblities:
1-bad ram module
2-remove ALL power supply to unit. Battery, power cord. Push and hold power button for 60 seconds. Try it now.
3-bad inverter board or backlight bulb.
このアンサーは役に立ちましたか?
One way or t'other, it did work. Thanks.
try adding a new os it may just need a new os no garentees that it will work
このアンサーは役に立ちましたか?
I added the ibm t43 hdd to my gateway laptop and it worked like normal
過去 24時間: 11
過去 7 日: 169
過去 30 日: 702
今までの合計 35,270
9 件のコメント
Does the pc give a series of beeps when you turn it on? If so how many beeps?
Jeff DeVaun さんによる
no it does not beep
mrsizzy209 さんによる
Yes 2 beep when powered up
terryconnock さんによる
Gateway lap top computer is on but the screen is black.
barbara rowlette さんによる
Yes it comes on! The screen just stays black
O'Sean Head さんによる
4件以上のコメントを表示
