メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
20回答 すべてを表示
Touchscreen Replacement Acting Erratically
Hi,
I just replaced the touchscreen on an iPad Mini.
The repair was done with the utmost care, but once laying the digitizer back down flat on the chassis, the touchscreen starts to register jittery and random input.
Once the touchscreen is lifted off the chassis, the problem goes away. Seems to be only when the digitizer makes contact with the aluminum frame.
If any one has any information on why this is happening and any possible fixes I would be very great full.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hello Lee,
This problem is caused either from;
Defective Glass
or
The strip of "padding" on the lower side of the LCD not being removed. I do not understand why you have to remove this padding, but you do. It looks like 5-6 (I don't remember the number in my head really..) cushions on a strip of tape that is very easily removed. (I believe there is one strip on each side of the LCD)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 161
