メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Dropped my phone in water, screen flickering, what do I do?
Alright, so the other day I dropped my iPhone 5 into the toilet, but I immediately took it out and turned it off. I then proceeded to put it into a bag of rice for the next few days. Everything works perfectly, I can use it, speakers work, everything. However, there a slight problem, the screen flickers a lot. I have it on full brightness and it constantly seems as if I'm just sliding the brightness from the lowest to the brightest. Is there anything I can do to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
Alex Trevino, here is my answer to a similar question. "Rice does not work. IOt will not prevent corrosion! The very first thing you want to do is to stop using your phone. Stop right now and do not continue to charge or sync it. The very next step I would do is to disassemble it by following this guide. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water. Use a soft brush and clean it very, very thouroughly with the sterile water. Depending on the amount of corrosion, you may have to remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Also, I suggest to replace the lightning connector. The guide for that is here Yes, do replace the battery for sure. Use this guide for that. Keep in mind that water damage is the hardest to troubleshoot and to repair. the issue with your screen could be the LCD itself or the backlight circuitry on your logic board. Hope this helps, good luck.
iPhoneの画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
iPhone 5 バッテリーの画像
ガイド
iPhone 5 のバッテリーの交換方法
難易度:
中レベル
15 minutes - 1 hour
iPhone 5 ロジックボードの画像
ガイド
iPhone 5 のロジックボードの交換
難易度:
中レベル
1 - 2 hours
iPhone 5 Lightningコネクターとヘッドホンジャックの画像
ガイド
iPhone 5のLightningコネクターとヘッドホンジャックの交換
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Dissassembling it will invalidate any warranties you have.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
the warranty cant do anything anyway when the iphone is water damaged. so in my humble opinion, just disassemble it, do wtv it takes so that you dont have to buy new iphone.
さんによる
コメントを追加
回答を追加する
Alex Trevino さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 45
過去 30 日: 169
今までの合計 55,487
