iPhone battery cycle counts
What happens with battery cycel counts after replacing the battery? Does it reset the cycles itself after installation a naew battery?
この質問は役に立ちましたか?
The cycle counts is the amount of times the battery has gone from 0% to 100%
So yes, changing the battery will reset the cycle count if it's a new battery, as the cycle count is associated with that battery. :)
このアンサーは役に立ちましたか?
Is there a method to find out what the count may be on a device ?
There certainly is, you can get a program on PC or Mac called ibackupbot, this allows you to check battery cycle without jail breaking etc. :)
What about coconut battery?
Yes, coconut battery is also a good application you can use. :-)
There’s a pretty tedious way to find out in your settings > privacy > Analytics & improvements > Analytics data > you’ll find a long list of data > scroll all the way down to log aggregated the very last one > click on that > copy all the content > paste onto your notes > top right corner press “find in notes” > type in “batterycyclecount” > the number will be your cycle count
When the iPhone Says Battery Cycle Count is 1 and The Battery is good but actually it drains fast after replace the battery thats because the new battery is a Chinese battery and its Chip is programed to only set
cycle count from 0 to 1 after first use and it will say wrong design capacity like for example
iPhone 6
Design Capacity = 1795 mAh
Current Max Capacity = 1875 mAh
and actually iPhone 6 Battery Design Capacity is 1810 mAh
so the Diagnostics tool will say the battery is good according to this Informations
(1875/1795)*100 = 105%~ Battery Life
this is a way to spot a fake battery by diagnostics.
このアンサーは役に立ちましたか?
Nothing is "reset". The cycle count is a piece of diagnostic data acheived by analysing the battery's reported data. A replacement battery is not going to "reset" the count to zero. The diagnostic tool is going to report the cycle count of the new replacement battery.
このアンサーは役に立ちましたか?
I bought a new battery for an iPhone. Cycle count at the start: 1.
After weeks of using/ reloading it is still 1.
Diagnostic tool says the battery capacity is ok, but it drains in a few hours. I've reloaded the battery dozens of times now, and still the cycle count is 1. The tool also indicates that the battery is in a constant state of discharge (1,9 watt)
The supplier told me these are original Apple batteries that are 'reconditioned'. They send me a new one, with the exact same problem.
Do you have an idea what's wrong with these batteries?
Is there any tool to 'reset' the battery, so it will do a normal charge-full-discharge cycle and count them aswell?
Hi William , did you found a solution to your cycle count 1 problem, pls do let me know my iPhone 5 also does same cycle count 1 always .
Nope! But i have seen several replacement batteries with the same problem. Seems the battery management software is not set correctly by the manufacturers/ reconditioners. I have another one here.. must have been reloaded for dozens of times, but still reports 1 load cycle .
過去 24時間: 1
過去 7 日: 18
過去 30 日: 83
今までの合計 9,933
