メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Computer Entertainmentが製造する家庭用ゲームコンソール。PS4としても知られています。2013年2月20日に初発表され、2013年11月15日に発売されました。
How much would it cost to fix my HDMI port?
My HDMI port isn't registering that the cord is plugged into it. It worked fine last night while I was playing, but when I brought it to my parents house it didn't work. My cord has been chipped on the top, one of the metal prongs is hanging down some. It also doesn't plug in all the way into the port. Could it be that one of the prongs got bent back or broken off in the port? How much would it cost to get this fixed?
(I've tried other HDMI cords as well, they started to chip on the top too after I tried plugging it into my Playstation.)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 27
14 件のコメント
i am in trying myself to replace it with another hdmi port i got from a laptop, due to there not being a supplier in Namibia i have to do with what i scrapped. So anyone with a pin layout of hdmi port (female) please comment
さんによる 共有
Believe this man,I took my grandson machine apart got the HDMI port off but cannot get it back on.Bought a sloder gun and cleaned everything up and guess what ,the HDMI pory will not stay on.Either gonna send out for repair or break down and buy another game system for my grandson.
さんによる 共有
Apparentlly i am having the same problem with my hdmi ports .When i push in my usb cable my controller is not connecting it is not even coming on i have tried other cables it is the same
さんによる 共有
you can find oem hdmi on ebay 5 bucks
さんによる 共有
Whenever i push turn on on my ps4 it makes clicking noises and doesn’t turn on and sometimes it does turn on but it goes into safe mode and i already downloaded a reinstallation update and it worked for a little bit then stopped again now it doesn’t even turn on
さんによる 共有
9件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
The price for this repair varies widely. Sony charges around $150 or more to do this repair while other repair shops charge a lot less. My repair shop charges $89.99 (parts, labor and return shipping) and there are others that are probably in that same price range.
Just be very careful with where you take it or send it. I get consoles in here all the time where someone has already tried to fix it and hasn't been able too...just today I had to fix one where someone tried to use some sort of epoxy to "glue" it back on...that didn't work so well!
Anyway, the point is that it's a difficult repair unless you have a good amount of electronics repair experience so just make sure that the person who fixes it knows what they're doing.
I hope this helps.
EDIT: Unfortunately, I no longer provide repair services as I’m focusing on my YouTube channel.
このアンサーは役に立ちましたか?
スコア 26
16 件のコメント:
What's the cost of an HDMI port? For consoles
さんによる 共有
The ports itself are not expensive. The cost involved is the difficulty / labor in taking out a HDMI port and putting a new one on without blowing some capacitors or breaking something.
さんによる 共有
Yes, @ben is right, the ports are not expensive ($5 - $10) but they are difficult to replace for most people.
さんによる 共有
Where are you located so I can send you my ps4 to fix
さんによる 共有
We are located near Portland, Oregon. You can get to our website by clicking my name.
さんによる 共有
11件以上のコメントを表示
コメントを追加
I do electronic repair I get these PS4 in my shop all the time and I will tell you that this is a very complex repair if you're not experienced an electronic repair then you do not need to continue this repair on your own this is a common issue with the PS4 with the HDMI port what happens is actually there's a couple reasons why these HDMI ports failed there's not just one reason...
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
How much do it cost to fix ps4
さんによる 共有
I. Pain Fix My Gadget $175 they were orginally try CD for $200 I wish I know o f some different and cheaper but
さんによる 共有
コメントを追加
In uae it only costs 175 aed which is 47 dollars (without shipping)
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Hi can u provide me location please in uae i live there thank you
さんによる 共有
How much is to fix my ps4 because it wont turn on
さんによる 共有
How much to fix my PlayStation it won’t update past 105.8 mb?
さんによる 共有
Are you still fixing PS4 pros my hdmi port is broke and need someone to fix it
さんによる 共有
コメントを追加
I have a ps4 but I guess the hdmi port not working It has sound couse wen I plug in the head set to the mic I can hear it on but no video on t.v any suggestion or should I get it fix n how much would it cost
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kcreed95 さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 31
過去 30 日: 92
今までの合計 141,648
