メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2376回答 すべてを表示
Is my phone fixable?
Hi, I am in major need of help with my iPhone 4! I recently took it to Squaretek here in town, they sell/repair phones. When I took my iPhone in there, they called 30 minutes later saying there was nothing they could do and... The only reason I am going through all this trouble to get it to turn on is because I have lots of pictures & memories I would love to get off of it! But it may be too late...The battery connector cable is ripped off my battery and also the emi shield as far as I understand...Is there really no way I can get this fixed??
Update
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
heres a picture
さんによる
コメントを追加
2件の回答
最も参考になった回答
yes place a new battery..
Update
the battery connector is ripped of including a solder pad. it is fixable but you will need some soldering skills. here maybe this can help..
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Really? Cause the guy at Squaretek told me in the first place it may just be the battery and need a new one..but then he said a part was "ripped" off that would cause the phone to never work again.
さんによる
Or let me ask this do you maybe know what th guy is talking about? what piece could be ripped off to completely destroy it?
さんによる
i think the ribbon cable of the battery is just destroyed . worst case scenario is you also pulled the battery connector from the logic board but that would be stil repairable..
さんによる
Maybe that's what I did! SO what would I need to do to fix it?
さんによる
Im going to send an image of the parts detached and missing
さんによる
1以上のコメントを表示
コメントを追加
You can replace the whole logic board out of the phone that wont turn on and put it in a new iphone. You can search in the ifixit repair manuals under iphone 4 logic board replacement. Then your photos and videos and everything else will be on the new phone. Happy to help!
Update
Now i see whats wrong. All you need is a new battery. Easy fix! And very cheap, starting at $20
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Amber Zabel さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 141
