メインコンテンツにスキップ
Dect 6.0 cordless phone system with answering system and caller identification. Repair for this device requires only common tools.
9回答 すべてを表示
My phone will not charge and I just replaced the battery?
I just replaced the battery on my phone, but the handset still will not charge. I'm not really sure what to do now. Do I have to buy a new handset?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
I have same issue w/3 new batteries & until yesterday, all 3 chargers worked. Now only 1 charger works, not base phone, but 1 of the extensions. Paper trick does not work, & I cleaned everything possible I could.
さんによる
コメントを追加
3件の回答
ベストアンサー
You should not have to buy a new handset. If replacing the battery did not work, you can try to buy a new AC power cord. To order a new cord, you can either call the Uniden parts department at 800-554-3988 or order it here online. You can check our troubleshooting page for more information.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
problem is of the three provided chargers, they all charge only one of the units, the other two do not charge at all, defect probucts for sure
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I notice mind was a problem with the handset sitting to far back, I place some paper folded up behind and they charged.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thanks I think that worked!
さんによる
さんによる
I had this issue after I moved my phone in my home office. I’d replace battery and it would stay charged for a few weeks but would not recharge. Turns out it didn’t like the power bar I had it plugged into. Plugged power source directly into wall and now it charged great.
さんによる
コメントを追加
回答を追加する
Hanna Daher さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 64
今までの合計 14,463
