メインコンテンツにスキップ
ニンテンドー3DSは任天堂の最新モデルです。より大きいスクリーンに、より長くなったバッテリー寿命と改良されたデザインが特長です。
412回答 すべてを表示
締切られた回答
3DS XL charger port broke. Soldered it, but still not working. Help!
So my son broke the charger port on his 3DS XL Pokemon Y Edition. I tried to desolder it. It worked, but I think I did some damage to the circuit lines and the silver contact areas. I bought a new charger port from Amazon, but when I try to connect it, it still will not charge. It actually does charge if I hold it a certain way, but I cannot solder it in that position.
Do I have to replace the whole motherboard? Or can I buy the CircuitWriter Precision Pen to try to fix?
Thanks!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Alexis, you do want to stay away from the circuitwriter pen. It makes a mess out of thing, and may work to repair traces, but not to attach components. If it "charge if I hold it a certain way" I'd reevaluate the soldering and redo it. Check the cable and make sure it is good.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 491
