back breaklights dont work,all other lights do. not a fuse or bulb.
need wiring diagram or hints to the problem.
The brake switch is located behind the brake pedal attached to the push rod..It could be faulty or stuck. Because its an important component I would replace it even if you find it's just stuck.
The Diagram is on this page...
このアンサーは役に立ちましたか?
Can see the diagram third brake light works nothing on the rear.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 569
Would the thrid brake light stll work with the brake switch blown?
Roger Blankenship さんによる
