Where is the fuel pump driver module located on my 03 tribute
where is the fuel pump driver module located on my 03 tribute
I believe that the Mazda Tribute and the Ford Escape share the same platform.
Here’s an image taken from the 2006 ELECTRICAL COMPONENT LOCATIONS – 01-06 ESCAPE section of the repair manual for a Ford Escape 2006.
On p.2 is says that the Fuel Pump Driver Module is located under centre of vehicle See. Fig.17
Here’s the image of Fig.17 (see p.31).
(click on image to enlarge for better viewing)
Not very informative but hopefully this may be of some help.
このアンサーは役に立ちましたか?
veraoscar2011 & @jayeff Ford did not use the FPDM prior to the 2005 model. Since the Mazda Tribute and Ford Escape pretty much share the same platform, it stands to reason that the Mazda would not have used it either.
Veraoscar2011 what year is your Mazda Tribute/Ford Escape
The answer from BurnieG is wrong. That's where the fuel pump is. The Fuel Pump Driver Module (FPDM) is a different part and I cannot find where it is located on mine either.
このアンサーは役に立ちましたか?
Same here, I cant find it..!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,778
