メインコンテンツにスキップ
1.6または1.8GHz デュアルコアプロセッサー、 2GBまたは4GBのSDRAM, 64GBまたは128GB SSD
192回答 すべてを表示
MacBook Air not charging, not turning on
Hi,
the Macbook Air 11" Mid 2011 is not charging the battery. The light of the Magsafe connector is always green. The computer will not start up with the Magsafe Poweradapter connected.
What I have tried so far:
  • used other power supply
  • replaced battery
  • reset SMC
  • reset PRAM
  • upgraded to Yosemite
After the battery change the computer will start up. But the computer will not charge the battery and the battery will run down even when the charger is connected.
Do you have suggestions on what I could change/check? (IO Board? Logic Board?)
Christian
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hi Christian,
I'd definitely check the I/O board first. It looks like the power from the charger isn't reaching the MacBook. Check the I/O board cable.
If that doesn't help, I'd also check the battery. It's pretty unlikely though, because the MacBook should run off external power if a charger is connected, no matter if a battery is available or not. But you never know.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thanks! I will check the cable and the IO Board.
Btw, with a multimeter do I have any luck in diagnosing the problem? I would probably just switch it but it is not so easy to find one in Germany.
Christian
さんによる
Same problem here, did you get to fix it?
さんによる
Same problem here. Did you get to fix it?
さんによる
コメントを追加
Hey Christian,
Am facing the same problem! Did you get to fix your MBA?
Tyson.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Christian van der Leeden さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 589
