メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
Where is the location of the back light fuse 820-3476-a?
I recently received a Macbook Pro A1502 Retina liquid spill with logic board number 820-3476-a. Unit boots up but no back light. Does anyone know the location of the back light fuse and wled driver? Crazy thing I had it working fine however when installing the OS back light just went out. Also how many volts should I be getting on pin one?
Thanks
I think this might be the location of the fuse
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Post some top and bottom view images of your logic board with your question. iFixitでの質問に画像を追加する方法
さんによる
yes F7700 is the fuse
さんによる
its probably fine though, they rarely blow even under liquid damage. start probing U7700 pins 17,18 and 5 what voltages do you have
さんによる
コメントを追加
2件の回答
最も参考になった回答
This is all wrong. You're talking about buying replacement chips without even having a schematic or a boardview. How can you know what to replace without even knowing where to measure??? How do you know the LED driver is bad?
Get a schematic and a boardview for 820-3476, then answer the following questions before further guessing.
1) Do you have 2.7v to 3v enable signal on pin 17 of U7700?
2) Do you have 5v on pins 5 and 18 of U7700?
3) Is R7733 0 ohms?
4) Is feedback network between R7731 and R7732 functioning properly? Traces to resistors good? Resistors themselves good?
5) What voltage do you have on backlight output, pin 1 of LCD connector? 0v? 12v? 20v? 27v?
このアンサーは役に立ちましたか?
スコア 7
3 件のコメント:
It's never the fuse on these. They are smart enough to turn off in case of a fault state.
さんによる
I have a question concerning this board I have the same 820 3476 a and I have an amber light all the time with battery or without and no power on can you tell me where to start with this the board looks very clean I had to replace the EFI chip because the board did not have one when I bought it doesn't need flashing how to do that Thank you for your help
さんによる
Hi
I have got 0V on pin 17 of U7700!!!
can you please lead me what should I do?
さんによる
コメントを追加
allenzabbal, you are correct. The reference designator is F7700 and it is a 3A 32V fuse in a 0603 package and the driver is U7700 and it is a LP8548B1SQ_-04 IC.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I checked the fuse and it is not open. Can the wled driver fail without and the fuse still ok? Do you know how may volts I should get on pin 1 on the lvds connector? thanks again.
さんによる
also where can I get the backlight package LP8548B1SQ? Would a LP8545SQ package work?
https://store.ti.com/LP8545SQENOPB-High-...
Thank you oldturkey03 for your help
さんによる
zzz AKA Louis Rossmann know his stuff along with oldturkey03
さんによる
コメントを追加
回答を追加する
allenzabbal さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 4,195
