メインコンテンツにスキップ
The Nokia Lumia 720 is a Windows Phone 8 device manufactured by Nokia. It was released in April 2013.
24回答 すべてを表示
締切られた回答
Microphone is not working
Hi, I have some problem with the microphone of lumia 720, some time it works and some time does not.
If it does not work and i will hit it will my palm, then it starts working, but again stops working after some time.
Is there any loose connection.
Or please help me out to fix this ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Many people have been experiencing this same issue after the 8.1 Cyan update. Did you receive this update lately? This is a software issue and I have not seen a proper fix for this at the moment. Although there may be one that I haven't heard of.
If you have not received that update then I would assume that you may have a loose connection. The only way to tell is to open up the phone and check it connections. If the connections look fine then I would think it would be a software problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,894
