メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
programming new optical drive for replacement
hi im just wondering if you have to program THE NEW optical drive IN XBOX ONE LIKE THE OLD 360S
THE TUTORIAL SHOWS THAT WE JUST SWAP THEM OUT BUT WILL GAMES WORK ON THE NEW DRIVE ?? i read that the drives are motherboard locked so how does this tutorial work ?? I also read that you have to swap out the board on the original drive to the new one in order for it to work but the tutorial does no such thing can someone shed some light on this thanks !!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
My Xbox one S has no optical drive at all.. How do I install a new one if I don't have a daughter board??
さんによる
@rottenova Simple, it's just not possible.
さんによる
コメントを追加
2件の回答
ベストアンサー
You have to swap the daughterboard from the origianal optical drive that came with the console from the factory with the daugtherboard with the new drive you are going to install. Each optical drive daughterboard is married to the motherboard so it must stay with that motherboard even if the drive is swapped out.
You will need to desolder the wires for the motor and solder them back on the replacement board.
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
I’ve done that, but my drive still won’t read games or DVDS what do I do in this case?
さんによる
@Nate Khan Replace the laser
さんによる
Is there anyway to know what daughterboard is attached to what motherboard? I have a bunch of systems that have been mixed up due to a big move. I can't find this answer anywhere. Specifically the Xbox One S.
さんによる
Same here^^^ is there away to swap out the motherboard chip that links the disc drive to one from another Xbox
さんによる
コメントを追加
I replaced my Disk drive on my original xbox one Halo version. With a Disk drive Order from Amazon. Unsoldered and re soldered daughter board to new Disk drive. It will take the disk in try to read it then I get a black-and-white Square message DVD Blu-Ray disk or game does not recognized please insert and DVD blu Ray disk or game. How do I get my xbox to start to read disks again
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sahilvinay さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 66
今までの合計 10,554
