メインコンテンツにスキップ
Manufactured in January 2013. Possesses full HD quality recordings with a 72x zoom.
9回答 すべてを表示
Why do the buttons on my Panasonic HC-V110 keep sticking?
Hello Fellow iFixit users,
I have experience difficulty with the buttons on my Panasonic HC-V110 camcorder.After I press a button it seems to stay pressed even after I release the button. This has just recently begun to happen, and it seems to be getting worse. Any suggestions on how to fix it?
Thanks for your help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi Brandi!
I have a couple possible solutions to your problem! One of which being that the buttons might be dirty- dust, crumbs, etc might have gotten stuck in/around the opening. This can definitely prevent the button from properly working and it is common in all electronics so don't worry! All you have to do is use a small, thin object like a toothpick to clean it out. Gently scrape around the button and in the crevices to clean it out.
Another solution could be to lightly tap on the button to make it "unstick". This could have happened due to aggressive use so be sure to be as careful as you can when pressing down on buttons.
Good luck, hope this helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brandi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 301
