メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
グーグル5番目のネクサスフォン。2013年10月31日に正式発表され、4.95インチ1080pディスプレイ、2.26GHz Snapdragonプロセッサ、LTEをサポート。Android 4.4.2、KITKATを搭載。製造はLG。
Liquid Damaged Daughterboard Help required
Some water got into my device after which i took off its back cover to clean it(Note only a few drops had gotten in and the device was running fine)Upon closing it back up i applied some glue to hold it there which leaked out a bit so i used a cleaner containing acetone which destroyed the matte coating on the sides and also some of it got into the micro usb port after which it started to malfunction and weird lines appeared on its display every now and then which i assume is because the micro usb port and lcd cable share the same daughterboard.To fix this i used isopropyl to clean the cable connectors on the board(was suggested this on various other websites) after which the lcd stopped working completely.(Note:The phone does switch on because i can hear my notifications and it vibrates on startup as ususal.)Please tell me how to clean the connectors and reverse the damage i caused by isopropyl(if its the culprit) or any other way to fix my device.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Hi , isopropyl would not harm your connectors or components at all unless you had power running through at the time. Any damage would have been from the glue or acetone. you would need to inspect the connectors and rest of the board closely with a magnifying glass for any glue or acetone residue. Acetone would definitely cause damage to the LCD connector our ribbon cable as it is not very plastic friendly. you may need a new front display. Hopefully its not an issue with the board.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the prompt reply.I have handed it in for repairing
さんによる
コメントを追加
回答を追加する
Mashhood さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 209
