メインコンテンツにスキップ
An android smartphone released by BLU Products in December 2013.
Why won't my blu phone come on
I have a Blu studio 5.0 ll and everytimes I tries to turn it on it won't turn on all the way it'll come on and stops at BLU.. Please help if you know whats going on thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 22
10 件のコメント
same with me ....... my blu phone is stick at the "BLU" logo when i start it up..........>_<
さんによる
Has the device seen any water?
さんによる
no it hasnt been in water
さんによる
My phone happened as it was on the charger....went to look at it & tried turning it on & only the BLU comes on the screen.......
さんによる
Mines starting to do the same thing but i have a 7.0
さんによる
5件以上のコメントを表示
コメントを追加
7件の回答
最も参考になった回答
It looks like the problem might be within the motherboard or the battery. In order to fix this, the motherboard and/or battery will have to be replaced. Visit the Troubleshooting page and repair guides for additional information.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have a Blu studio mega 6.0 when I bought the phone I charged it for a hour it still won't come on and I put it on my PC and it's still not working what do I need to do or can someone please help it's a brand new phone
さんによる
コメントを追加
check the voltage on your battery likely it is shorted and pushing to much voltage see it all the time
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How cAn i check my battery if i have a 7.0??
さんによる
コメントを追加
I dropped my blu cell phone bottom side first on a can of Lysol now it doesn't turn on, or power up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Blue phone turn on and off screen wore come in
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my battery is new and the same still occurs....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It has a select boot mode on the front of the phone it won't turn on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The phone has been wet or the phone is bricked bad battery or cable ,charger if it is wet trying to flash the combination file will permanently damage the device short answer if phone is wet inside it must completely dry before turning it on then replace charger and cable then if battery is removable test the voltage on it if it's less then 2.5v battery is damaged if all else is good flash the combination file with odin or compatible software fir blu
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kam さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 19
今までの合計 4,412
