メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
iPhone 5 no service or no signal.
I had a iPhone 5 with liquid damage. I cleaned all the corrosion and the phone worked all fine.
Now after 5 months the phone doesnt find any service or signal. tried resetting the network settings, new software, used different sim cards
tried another antenna cable ( dock connector )even used another back case. imei, baseband all ok. date, time ok.
My question is which components do i have to troubleshoot so i can find a solution. Which components or ic's is related to no network, or no service. I got a scrap iphone 5 motherboard were i can take out components. Got the necessary skills to solder. got also the schematics.
Hope you guys can help me out
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
hj gaat aan maar krijg hem niet uitget en voledeg wit scherm
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had this problem when i changed powerflex on iphone 5. The screwdriver slipped and it then wouldnt find signal.
I found out this was missing:
After soldering this it had fine signal again. Maybe you have some corrision around this area, that has to be cleaned.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have this problem and I think this could be a solution for me. Can somebody explain this a bit more specific, what is missing?! I also have iPhone 5C so if anyone have fixed this in iPhone 5C and would be willing to share some guidance or even pictures, i would be more than grateful.
さんによる
コメントを追加
回答を追加する
iOzzy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 3,136
