メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
Missing what I think is a Resistor but not sure exactly.
Ok so I have a water damaged IPhone 5c . I disassembled and cleaned with 99% alcohol but still nothing so i proceeded to remove the Metal shields where i found more corrosion which i cleaned with a brush and alcohol .
After cleaning i reassembled with a new battery . The phone shows no signs of life other than the board gets hot enough to burn in this area SHOWN IN BLACK .
Now i noticed that what looks like a resistor but is probably not was covered in corrosion and looked damaged and seemed to be the source of the heat. would burn finger when touched. So i successfully desoldered it and no more heat but still no life in the phone. I'm looking to find out what this part is called so i can get a replacement to see if it solves the issue.
Part shown in black
These images were taken from ifixit i just highlighted the part i am referring to.
Thank you in advanced.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
st3v3w, that is reference designator L11 which is a 2.2UH-20%-1.7A-200MOHM inductor (coil). It is listed as a TFA201610G which is manufactured by TDK
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
Thank you oldturkey03 your knowledge is greatly appreciated.
さんによる
Sorry to bother you again but i have been looking for this part but seem to be having trouble find it . do you have any recommendations as to where i could find it?
さんによる
Where in the world are you located?
さんによる
Canada , New Brunswick .
さんによる
Lets see if we can find the right component. If you can, measure the components physical size. That way we could find an equivalent package size. I'd try to check Murata's LQM2HPN2R2MGH and see if the dimensions would be workable. You doing okay with all the snow and bad weather?
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
st3v3w さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 161
