メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
An affordable Windows phone by Nokia, released April 2013.
LCD does not turn on.
Hello! I will describe my problem shortly. This afternoon I replaced the digitizer because it was broken. The glue of the broken digitizer covered a part of the LCD (the frame) and the lcd went out from its slot when I separated the digitizer from the rest of the body. In this case I had the small LCD from an hand and its slot (the part in which you collocate the chip with camera etc) from the other hand. The problem is: when I mounted all the pieces toghether even the new digitizer all worked fine except the LCD that was black (the phone turns on I'm sure of that)
How is it possible?
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
If the LCD's ribbon cable was stressed it may have a small tear in it, which would prevent the lcd from working. They are almost impossible to repair too.
Or maybe your LCD's ribbon connection to the logic board is loose or not making contact. It may need pushed in farther to the connection.
I would say double check the ribbon cables.
I have torn some accidentally and sometimes they tear where you least expect.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Andrea Ds さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 121
