メインコンテンツにスキップ
Released in February 2012, by model number DSC-H55
5回答 すべてを表示
Is there any way to change my camera to a different color?
I received this camera as a gift from my grandmother. Unfortunately, so did my other three cousins. I want to make my camera look different than theirs. Is there any way I can possible change the color of the shell of my camera?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Yes, it is possible to change your camera to a different color! First i am assuming that you're interested in changing the black factory housing (outer shell) of the camera. To do this you will need to follow a few simple steps. First to complete this task you will need a Philips head screwdriver and a plastic wedge or splitting tool. Ok, now you want to turn the camera over and remove the three screws holding the bottom plate. Now remove the two screws on the right side of the camera, make sure to keep these 5 screws in a safe spot to be sure not to lose them. These 5 screws are all the same size so they do not have to be put in the respected spot which taken from, any five of the spots will work. Next open the battery compartment and slide your splitting tool between the crevice of the back shell around the screen until you are able to pull it off. Next remove the left face and there should be two more screw that need to be removed so that the front shell can be removed. Once this step is complete replace the front face with the one of your desired color, and screw back in the screws which hold the front shell. Replace the left wall with the new color by sliding it into place. Now put your new back face on around the lcd screen and bottom plate in place. Screw in the bottom three screws and the two which go on the right side of the camera. You now have a new color camera to stand out from your cousins, congratulations!!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Vanessa Forero さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 537
