Why isn't my tablet turning on?
I pushed the power button and nothing happens.
Hi @randolphmora123,
Does the tablet show that it is charging when you connect the charger to it?
What % of charge is the battery icon showing when you try to charge the battery only and not switch on the tablet?
If it shows that it is charging allow it to fully charge and then try turning it on.
If it still won’t turn on after it is fully charged, can you start and use the tablet with the charger connected and switched on?
If so, then the battery may be faulty and needs to be replaced.
このアンサーは役に立ちましたか?
For more information about your XO Tablet please go to the following website: http://xotablet.com/
Also, you can check out the troubleshooting page for this device!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,878
4 件のコメント
my USB/charge port is loose. I know why it won't turn on. I need to know how to get it repaired.
brobisonus さんによる
y is not truinng on
darius matthews さんによる
I push the power button and it doesnt come on.
randolphmora123 さんによる
Why my vivitar tablet wont turn on
Beatricegrace さんによる
